RTEMS Logo
RTEMS 4.10.0 On-Line Library
Region Manager REGION_DELETE - Delete a region
14.4.3: REGION_DELETE - Delete a region
CALLING SEQUENCE:
procedure Region_Delete (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - region deleted successfully
RTEMS.INVALID_ID - invalid region id
RTEMS.RESOURCE_IN_USE - segments still in use
DESCRIPTION:
This directive deletes the region specified by id. The region cannot be deleted if any of its segments are still allocated. The RNCB for the deleted region is reclaimed by RTEMS.
NOTES:
This directive will not cause the calling task to be preempted.
The calling task does not have to be the task that created the region. Any local task that knows the region id can delete the region.
