RTEMS Logo
RTEMS 4.10.0 On-Line Library
Region Manager Releasing a Segment
14.3.5: Releasing a Segment
When a segment is returned to a region by the rtems.region_return_segment directive, it is merged with its unallocated neighbors to form the largest possible segment. The first task on the wait queue is examined to determine if its segment request can now be satisfied. If so, it is given a segment and unblocked. This process is repeated until the first task's segment request cannot be satisfied.
