RTEMS Logo
RTEMS 4.10.0 On-Line Library
Partition Manager Obtaining Partition IDs
13.3.2: Obtaining Partition IDs
When a partition is created, RTEMS generates a unique partition ID and assigned it to the created partition until it is deleted. The partition ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.partition_create directive, the partition ID is stored in a user provided location. Second, the partition ID may be obtained later using the rtems.partition_ident directive. The partition ID is used by other partition manager directives to access this partition.
