RTEMS Logo
RTEMS 4.10.0 On-Line Library
Event Manager Sending an Event Set
11.3.1: Sending an Event Set
The rtems.event_send directive allows a task (or an ISR) to direct an event set to a target task. Based upon the state of the target task, one of the following situations applies:
