RTEMS Logo
RTEMS 4.10.0 On-Line Library
Message Manager Receiving a Message
10.3.3: Receiving a Message
The rtems.message_queue_receive directive attempts to retrieve a message from the specified message queue. If at least one message is in the queue, then the message is removed from the queue, copied to the caller's message buffer, and returned immediately along with the length of the message. When messages are unavailable, one of the following situations applies:
If the task waits for a message, then it is placed in the message queue's task wait queue in either FIFO or task priority order. All tasks waiting on a message queue are returned an error code when the message queue is deleted.
