RTEMS Logo
RTEMS 4.10.0 On-Line Library
Semaphore Manager Background
9.2: Background
  • Semaphore Manager Nested Resource Access
  • Semaphore Manager Priority Inversion
  • Semaphore Manager Priority Inheritance
  • Semaphore Manager Priority Ceiling
  • Semaphore Manager Building a Semaphore Attribute Set
  • Semaphore Manager Building a SEMAPHORE_OBTAIN Option Set
  • A semaphore can be viewed as a protected variable whose value can be modified only with the rtems.semaphore_create, rtems.semaphore_obtain, and rtems.semaphore_release directives. RTEMS supports both binary and counting semaphores. A binary semaphore is restricted to values of zero or one, while a counting semaphore can assume any non-negative integer value.
    A binary semaphore can be used to control access to a single resource. In particular, it can be used to enforce mutual exclusion for a critical section in user code. In this instance, the semaphore would be created with an initial count of one to indicate that no task is executing the critical section of code. Upon entry to the critical section, a task must issue the rtems.semaphore_obtain directive to prevent other tasks from entering the critical section. Upon exit from the critical section, the task must issue the rtems.semaphore_release directive to allow another task to execute the critical section.
    A counting semaphore can be used to control access to a pool of two or more resources. For example, access to three printers could be administered by a semaphore created with an initial count of three. When a task requires access to one of the printers, it issues the rtems.semaphore_obtain directive to obtain access to a printer. If a printer is not currently available, the task can wait for a printer to become available or return immediately. When the task has completed printing, it should issue the rtems.semaphore_release directive to allow other tasks access to the printer.
    Task synchronization may be achieved by creating a semaphore with an initial count of zero. One task waits for the arrival of another task by issuing a rtems.semaphore_obtain directive when it reaches a synchronization point. The other task performs a corresponding rtems.semaphore_release operation when it reaches its synchronization point, thus unblocking the pending task.
