RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager Obtaining Timer IDs
8.3.2: Obtaining Timer IDs
When a timer is created, RTEMS generates a unique timer ID and assigns it to the created timer until it is deleted. The timer ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.timer_create directive, the timer ID is stored in a user provided location. Second, the timer ID may be obtained later using the rtems.timer_ident directive. The timer ID is used by other directives to manipulate this timer.
