RTEMS Logo
RTEMS 4.10.0 On-Line Library
Clock Manager CLOCK_GET_SECONDS_SINCE_EPOCH - Get seconds since epoch
7.4.5: CLOCK_GET_SECONDS_SINCE_EPOCH - Get seconds since epoch
CALLING SEQUENCE:
procedure Clock_Get_Seconds_Since_Epoch(
   The_Interval :    out RTEMS.Interval;
   Result       :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - current time obtained successfully
RTEMS.NOT_DEFINED - system date and time is not set
RTEMS.INVALID_ADDRESS - the_interval is NULL
DESCRIPTION:
This directive returns the number of seconds since the RTEMS epoch and the current system date and time. If the date and time has not been set with a previous call to rtems.clock_set, then the RTEMS.NOT_DEFINED status code is returned.
NOTES:
This directive is callable from an ISR.
This directive will not cause the running task to be preempted. Re-initializing RTEMS causes the system date and time to be reset to an uninitialized state. Another call to rtems.clock_set is required to re-initialize the system date and time to application specific specifications.
