RTEMS Logo
RTEMS 4.10.0 On-Line Library
Interrupt Manager INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
6.4.5: INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
CALLING SEQUENCE:
function Interrupt_Is_In_Progress return RTEMS.Boolean;
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive returns TRUE if the processor is currently servicing an interrupt and FALSE otherwise. A return value of TRUE indicates that the caller is an interrupt service routine, NOT a task. The directives available to an interrupt service routine are restricted.
NOTES:
This directive will not cause the calling task to be preempted.
