RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager TASK_VARIABLE_DELETE - Remove per task variable
5.4.19: TASK_VARIABLE_DELETE - Remove per task variable
CALLING SEQUENCE:
procedure Task_Variable_Delete (
   ID                  : in     RTEMS.ID;
   Task_Variable       :    out RTEMS.Address;
   Result              :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - per task variable added successfully
RTEMS.INVALID_ID - invalid task id
RTEMS.NO_MEMORY - invalid task id
RTEMS.INVALID_ADDRESS - task_variable is NULL
RTEMS.ILLEGAL_ON_REMOTE_OBJECT - not supported on remote tasks
DESCRIPTION:
This directive removes the given location from a task's context.
NOTES:
NONE
