RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager TASK_WAKE_AFTER - Wake up after interval
5.4.14: TASK_WAKE_AFTER - Wake up after interval
CALLING SEQUENCE:
procedure Task_Wake_After (
   Ticks  : in     RTEMS.Interval;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - always successful
DESCRIPTION:
This directive blocks the calling task for the specified number of system clock ticks. When the requested interval has elapsed, the task is made ready. The rtems.clock_tick directive automatically updates the delay period.
NOTES:
Setting the system date and time with the rtems.clock_set directive has no effect on a rtems.task_wake_after blocked task.
A task may give up the processor and remain in the ready state by specifying a value of RTEMS.YIELD_PROCESSOR in ticks.
The maximum timer interval that can be specified is the maximum value which can be represented by the uint32_t type.
A clock tick is required to support the functionality of this directive.
