RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager TASK_SELF - Obtain ID of caller
5.4.3: TASK_SELF - Obtain ID of caller
CALLING SEQUENCE:
function Task_Self return RTEMS.ID;
DIRECTIVE STATUS CODES:
Returns the object Id of the calling task.
DESCRIPTION:
This directive returns the Id of the calling task.
NOTES:
If called from an interrupt service routine, this directive will return the Id of the interrupted task.
