RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager Task Mode
5.2.5: Task Mode
A task's execution mode is a combination of the following four components:
It is used to modify RTEMS' scheduling process and to alter the execution environment of the task. The data type rtems.task_mode is used to manage the task execution mode.
The preemption component allows a task to determine when control of the processor is relinquished. If preemption is disabled (RTEMS.NO_PREEMPT), the task will retain control of the processor as long as it is in the executing state -- even if a higher priority task is made ready. If preemption is enabled (RTEMS.PREEMPT) and a higher priority task is made ready, then the processor will be taken away from the current task immediately and given to the higher priority task.
The timeslicing component is used by the RTEMS scheduler to determine how the processor is allocated to tasks of equal priority. If timeslicing is enabled (RTEMS.TIMESLICE), then RTEMS will limit the amount of time the task can execute before the processor is allocated to another ready task of equal priority. The length of the timeslice is application dependent and specified in the Configuration Table. If timeslicing is disabled (RTEMS.NO_TIMESLICE), then the task will be allowed to execute until a task of higher priority is made ready. If RTEMS.NO_PREEMPT is selected, then the timeslicing component is ignored by the scheduler.
The asynchronous signal processing component is used to determine when received signals are to be processed by the task. If signal processing is enabled (RTEMS.ASR), then signals sent to the task will be processed the next time the task executes. If signal processing is disabled (RTEMS.NO_ASR), then all signals received by the task will remain posted until signal processing is enabled. This component affects only tasks which have established a routine to process asynchronous signals.
The interrupt level component is used to determine which interrupts will be enabled when the task is executing. RTEMS.INTERRUPT_LEVEL(n) specifies that the task will execute at interrupt level n.
The set of default modes may be selected by specifying the RTEMS.DEFAULT_MODES constant.
