RTEMS Logo
RTEMS 4.10.0 On-Line Library
Initialization Manager SHUTDOWN_EXECUTIVE - Shutdown RTEMS
4.4.5: SHUTDOWN_EXECUTIVE - Shutdown RTEMS
CALLING SEQUENCE:
procedure Shutdown_Executive(
  Status : in     RTEMS.Unsigned32
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive is called when the application wishes to shutdown RTEMS and return control to the board support package. The board support package resumes execution at the code immediately following the invocation of the rtems.initialize_executive directive.
NOTES:
This directive MUST be the last RTEMS directive invoked by an application and it DOES NOT RETURN to the caller.
This directive should not be invoked until the executive has successfully completed initialization.
