The clock facilities of the clock manager operate upon calendar time. These directives utilize the following date and time record for the native time and date format:
type Time_Of_Day is
record
Year : RTEMS.Unsigned32; -- year, A.D.
Month : RTEMS.Unsigned32; -- month, 1 .. 12
Day : RTEMS.Unsigned32; -- day, 1 .. 31
Hour : RTEMS.Unsigned32; -- hour, 0 .. 23
Minute : RTEMS.Unsigned32; -- minute, 0 .. 59
Second : RTEMS.Unsigned32; -- second, 0 .. 59
Ticks : RTEMS.Unsigned32; -- elapsed ticks between seconds
end record;
The native date and time format is the only format
supported when setting the system date and time using the
rtems.clock_set directive. Some applications
expect to operate on a "UNIX-style" date and time data structure. The
rtems.clock_get_tod_timeval always returns
the date and time in struct timeval format. The
rtems.clock_get directive can optionally return
the current date and time in this format.
The struct timeval data structure has two fields: tv_sec
and tv_usec which are seconds and microseconds, respectively.
The tv_sec field in this data structure is the number of seconds
since the POSIX epoch of January 1, 1970 but will never be prior to
the RTEMS epoch of January 1, 1988.
